  1. Hi !
    An mpeg file i have (btw, it's been ripped the wrong way round - resolution 480*576) has an introduction sequence and when it comes to the actual movie, it's diplayed on the upper 80 % of the screen and the remaining 20 % of the screen are taken by the bottom of the last frame of the introduction sequence. I'm not sure this is clear, but i'd like to know if someone (understood what i said ) knows how to permanently remove the lower part of a movie. I have Adobe Premiere. I've tried to combine "clip" and "camera view - zoom" effects but got no good result.
    I was wondering if could be the resolution of the intro sequence that's been applied the whole mpeg.
    Thanx for your help.
  2. Originally Posted by FWNick
    Hi !
    Thats the correct resolutio for PAL SVCD.
    You could re-encode with TmpGenc and use CLIP FRAME.
  3. I'll try this. Thank you !
  4. It works perfectly !!! Thank You VERY much !!!
