well i was wonderin what r the settings changes that will have serious effect on the output filesize of tmpgenc
i also have tried convertin 2 movies with it from mpg to mpg2(m2v) and i realised that the playtime is not really normal i mean the clip seems fine but if someone says hi at the 13th min of the original clip he'd probably say it at 13 or 11 in the output file ,i also think that mediaplayer counts the second faster than a real second while playin the output file ,is there something wrong? will this affect the audio when i add it in the file?
thnx![]()
The only two things that affect the size of an mpeg file, from any encoder, are playing time and bitrate.Originally Posted by brock_leznar
As to your other question about playing time, I am not sure what you mean.
TMPGEnc Maximum File Size for Authoring?
By cym in forum Authoring (DVD)Replies: 3Last Post: 26th May 2010, 01:55 -
picture size difference after transcoding (TMPGenc 2.5)
By jakewoodblues in forum Video ConversionReplies: 12Last Post: 27th Apr 2010, 20:57 -
Why does TMPGEnc DVD Author3 say that my file size is too big?
By jimdagys in forum Authoring (DVD)Replies: 4Last Post: 7th May 2008, 19:48 -
TMPGenc DVD Author 3 Maximum Size
By Shadowofthedarkgod in forum Authoring (DVD)Replies: 5Last Post: 6th Apr 2008, 18:59 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 14:30
