Hi all,
I have mpegs and whenever i want to put to dvd nero or arcsoft wants to transcode it again......what program jus burns the mpeg without coding again ?..
Thanks for any reply
If you are trying to burn as VCD the mpeg has to meet strict specifications for resolution and bitrate. If the mpeg file does not meet these specifications then nero will try to reencode it to make the file VCD compliant.
You have 3 options.
Turn off standard compliance in Nero and create an XVCD, this may or may not play on your standalone DVD player. When you select VCD as a new compilation in nero on the Video CD tab there is a check box for create standard compliant CD. Uncheck it.
Re-encode the file to make it VCD compliant. Dont use Nero for this as it is a poor encoder, use TMPGEnc. You can then use Nero to burn your compliant VCD
Burn the mpeg file as data to a CDR. Some DVD players can play raw mpeg files but not many. -
Are you using a VCD template
I suggest you read this guide
https://www.videohelp.com/tmpgenc.htm
Looking for a BD Authoring software that dont re-encode MPEG2 Files
By faramith in forum Authoring (Blu-ray)Replies: 11Last Post: 14th Dec 2011, 04:39 -
Encode YouTube video to MPEG-2
By RL in forum ffmpegX general discussionReplies: 4Last Post: 31st Jan 2011, 23:31 -
Can't encode VOB to MPEG-2
By radellaf in forum ffmpegX general discussionReplies: 3Last Post: 11th Jun 2008, 19:08 -
National Treasure 2 will not encode to MPEG
By shoeshine in forum DVD RippingReplies: 1Last Post: 10th May 2008, 10:52 -
Dont get how to apply filter to a MPEG-2
By noob4ever in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2008, 20:01
