Did anyone use Tmpeg DVD Author to author a DVD with switchable subtitle? I prepare my VOB by using IFO Edit (mux with 2 subtitles), I have tested with PowerDVD, the VOB files generated by IFO Edit play fine, subtitles are switchable and working fine. However, after I import the same set of VOBs into Tmpeg DVD Author (I made a simple menu with it), the subtitle button is deemed (grayed) in PowerDVD, no subtitle is selectable. How can I fix this problem. I did exactly the same as suggested by a member in this forum (sorry, I forgot his name), he suggested the following:
-->Click on the Open Button, and open the VTS_01_0.IFO generated by IFOEdit. CLick on the (-) button to open the tree view.
-->Click on VTS_PGC_ITI (on the tree view) and them on the (+) that will appear. Now click on "VTS_PGC_1"
-->On the window in the bottom, scroll down till you find "sub-picture stream 1 status". Double click in this line, and copy to clipboard the value that appears in a messagebox (something like "-2130706432")
-->Now click on the (-) sign in the top of tree (VTS_01_0.IFO) to close the tree. Click on the open button again and open the VTS_01_0.IFO generated by Tmpeg DVD Author. Find the "sub-picture stream 1 status" for this file in the same way you did before. Notice it has a zero value. Double click on it and paste the value you got from the other IFO.
-->Repeat the above steps to VTS_PGC_2, VTS_PGC_3 and so on (if it exists). Also repeat this for the second subtitle stream ("sub-picture stream 2 status"), if it exists
-->Now your DVD already has subtitles.
Even I have done exactly what was mentioned above, I still couldn't select subtitle, in fact, there was no subtitle at all. Any help will be highly appriciated!
TDA doesn't support subtitles. You can add your VOBs to the project but TDA just takes video and one audio track from source VOB and remux them again.
Tmpeg DVD Author doesn't like low quality captures?
By the wordsmith in forum Video ConversionReplies: 9Last Post: 20th Mar 2008, 07:30 -
Home DVD Player that supports arabic (Unicode) subtitles
By waza in forum SubtitleReplies: 0Last Post: 7th Sep 2007, 19:28 -
Does TMPEG DVD author support multi VTS
By perfection in forum Authoring (DVD)Replies: 1Last Post: 31st Aug 2007, 17:19 -
why subtitles move with TMPEG DVD Author
By Konde in forum Authoring (DVD)Replies: 0Last Post: 22nd Jul 2007, 01:21 -
Trouble with TMPEG DVD Author
By acidcrash in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 05:31
