I recently got myself a Medion MD 40570 settop DVD Recorder. It works very good at recording from cable/analog/etc.
It has varying record "speeds" of 1-6 hours, but I didn't want to waste that much disk space when I was recording something just over the hour mark.
I was recording my Laserdisk of Schindler's List onto disk. It has a runtime of 3:17. My plan was to record the first 3 hours of it on one disk, then the last bit on asecond disk. One done, I'd feed them to the PC and combine/re-author them with DVD Shrink.
Here's what happened:
DVD Shrink didn't like anything about the disk at all! I ripped the files and still nothing.
looking at the file structure, I noticed that the movie seemed to be recorded on the disk twice! Two complete set of movie files (one on vts01 and one on vts02).
I opened the vob files in DVD2AVI, I found that the recordrd screen resolution was 360x480!!!!
They play full screen, for some reason though, through the dvd players, and Windows Media Player.
My unit is the only one I've had any experience with.
Is this normal for standalone recorders to record like this? Half the horizonal, and why on earth would it record twice? Is my plan of piecing the video together, to fit all on one disk without wasted space (or encoding) doomed to failure?
"I think I know exactly what I mean, when I say it's a Shpadoinkle day!"
Originally Posted by mijman
see https://www.videohelp.com/glossary#Half%20D1Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
OK....found it. This fix is thanks to Movie Freak....ripping with DVDDecrypter most likely.
1. Rip the dvd in in IFO mode. Rip it to your hard disk, do each recording to a separate folder
2. open IFOEdit, open the IFO in it from one of your folders, Go to VOB Extra's, Create New IFO's.
3. when the window comes up, make sure the destination directory is in that folder. click ok. it will create new IFO's
4.Open dvd shrink.
5.Open files ----> choose the IFO in the folder you have just created with the new IFO's -
Ok, I'll have to try that. I was planning to use Ifoedit anyway to add chapters.
Any idea why the video was recorded twice? Do they get merged?
I looked at a disk I recorded in the 2 hour mode, and it's full frame, and only recorded once on the disk. So, I'm confused as to why it does what it does. I'll just stop using the longer modes if this is what it does."I think I know exactly what I mean, when I say it's a Shpadoinkle day!"
drawer won't shut on Medion DVD player??
By wundahoss in forum DVD & Blu-ray RecordersReplies: 6Last Post: 21st Sep 2010, 02:15 -
Recording issues with LG DVB-T HDD/DVD Recorder RHT497H
By Geex360 in forum DVB / IPTVReplies: 1Last Post: 22nd Feb 2010, 09:43 -
DVD Recorder - Quality Issues (NOT PC TYPE)
By jaffacaique in forum Video Streaming DownloadingReplies: 11Last Post: 1st Apr 2009, 15:45 -
WinTV-PVR-USB2 Questions/Issues
By SuPeRFr0sT in forum Capturing and VCRReplies: 4Last Post: 30th Sep 2008, 06:39 -
Sony DVD recorder and lip sync issues
By zdamons in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Jan 2008, 13:56
