Results 1 to 9 of 9
  1. I recently bought a new FX5200 video card and I noticed it was AGP4x/8x. On my mother board I forgot it was AGP Pro. My question is if I can still use this card?
  2. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    Do you know the exact mother board you have?
    SLICK RICK
    Nobody likes a bunch of yackity-yack.
  3. ASUS P4B533-E. I looked through the website but it wasn't much help.
  4. Isn't AGP Pro just another name for AGP 2x? Or is it 4x?
  5. The AGP Forum (agpforum.com) says it's an extension of AGP4x but it also lists differences.
  6. maybe you should try it out then. maybe the video card will run in AGP 4x mode.
  7. Member SLICK RICK's Avatar
    Mar 2003
    Specs:
    Asus P4B533-E
    Processor - Supports Intel Pentium 4 (Willamette/Northwood) processors of 400/533 MHz bus speed;
    - Intel Celeron (Willamette) of 400 MHz bus speed;
    - Socket 478
    Chipset i845E - Northbridge Intel® 82645E Memory Controller Hub (MCH);
    - Southbridge Intel® 82801DB Enhanced I/O Controller Hub (ICH4)
    System memory - Three 184-pin slots for DDR SDRAM DIMM
    - Maximum memory capacity up to 2GB
    - Supports PC1600/2100 memory
    Graphics - AGP Pro slot, supporting the 4x mode
    Expansivity - Six 32-bit PCI Bus Master slots;
    - One CNR slot;
    - Six USB 2.0 ports (4 integrated + 2 additional);
    - Two IEEE1394 (Firewire) ports;
    - Support of Asus iPanel;
    - Support of Smart Card Reader: PS/SC-compatible Smart Cards Reader;
    - Support of Secure Digital Reader and Memory Stick Reader
    Overclocking potentials - FSB adjustable between 100MHz to 200MHz in 1MHz Increments;
    - Processor/memory, AGP voltage adjustable
    On-board functionality - Integrated hardware audio CMedia CMI8738;
    - LAN controller Intel 82562ET;
    - NEC controller for IEEE-1394 bus support
    Disk subsystem - 2 channel UltraDMA/100/66/33 Bus Master IDE (supports up to 4 ATAPI-devices);
    - Additional IDE Raid controller (IC Promise PDC20276, 2 channel IDE, supports ATA33/66/100/133 & RAID 0, 1 with a support of up to 4 ATAPI-devices);
    - Support of LS-120/ZIP/ATAPI CD-ROM
    BIOS - 4MBit Flash ROM;
    - Award BIOS Phoenix with support Enhanced ACPI, DMI, Green, PnP Features and Trend Chip Away Virus;
    - Asus EZ Flash Technology;
    - Asus MyLogo2 Technology;
    - Multi-languages BIOS
    Miscellaneous - One FDD port, two serial and one parallel ports, PS/2 ports for mouse and keyboard;
    - Onboard power LED indicator;
    - AGP Warning LED;
    - Asus POST Reporter Technology;
    - Asus Q-Fan Technology;
    - STR (Suspend to RAM);
    - SPDIF In\Out
    Monitoring - Case integrity check;
    - Monitors the processor temperatures, voltages, rotational speeds at the 3 fans
    Power management - ACPI/APM
    - Wake-up from modem, mouse, keyboard, LAN, timer and USB
    Power - Standard 20-pin power socket ATX (ATX-PW);
    - Additional 4-pin power socket;
    - Standard 12V power socket (Asus EZ Plug Technology)
    Dimensions - ATX form factor, 245mm x 305mm (9.63" x 12")
    SLICK RICK
  8. Thanks a lot Rick I didn't catch that.
  9. Member SLICK RICK's Avatar
    Mar 2003
    No problem.
    SLICK RICK
