  1. I have created an MPEG2 file with MGI VideoWave 4. with a CBR of 1700 and resolution of 720x567. I want to resize, edit, cut this file in TMPEG but it does not allow to open the file. Unsupported or invalid it write. The file itself can be opened however with Win DVD.
  2. email me I'll send you a codec that will fix it
  3. You could also framserve using avisynth and mpeg2dec plugin
  4. Yuo could also send it over via dvd2avi (pretend that its a vob)
  5. i installed a program called Elecard Mpeg2 Player. after that it worked for me. i think it contains the codecs.....
  6. I did that too, i can play MPEG-2 files, but cant open them in TMPGenc, its annoying.
  7. Is anyone reading my previous post????
    send me an email
    I'll email you a codec
    you can open mpeg-2 files in TMPGEnc
    it does not have a "watermark" like the Elecard codec
    May 2001
    Ramstein, Germany
    send it to me!
