I just got the upgrade for Premiere 5.1 to Pro and have quickly put together some vacation video and burned it to a DVD. The total disk space was a little over 3 GIG and took about 12 hours to burn.
Two questions about this:
1- IS THIS NORMAL? maybe I have some setting that I need to adjust or something but this seemed to be an extreemly long time.
2-IS THERE ANY WAY TO MAKE COPIES OF MY MOVIES THAT WON'T TAKE THIS LONG? again maybe my ignorance on the subject is the culprit here.
Can anyone at least point me in the right direction?
Thanks.
1) This is normal! Encoding from avi to mpeg2 takes a long time. Depending on the settings, you can encode faster but you would lose quality.
2) You should never burn directly to DVD. You should export your video to a image file. Once your encoding is complete you burn your DVD.
I am using Premiere Pro to do exactly the same kind of project! What I do is I start the encoding before going to bed.... The next morning I wake up with my image file and burn it to DVD -
I actually tried this (I think). I copied the DVD files to my hard drive then tried to copy those to my DVD-R. But I couldn't find the right program to do that. Should I be looking within Pro?You should never burn directly to DVD. You should export your video to a image file. Once your encoding is complete you burn your DVD.
I do no actually use the "Create a DVD" function.
I use Adobe media encoder (In the Export function of Premiere Pro) to make a DVD MPEG2 compliant file.
Then you have to use another software to author a DVD.
Check in the AUTHOR section or in TOOLS.. You will find plenty software that can do that, from freeware to very expensive one.
With the authoring software, you import your MPEG2 file and create a DVD. -
I've got a Sony VIAO that came with "Click to DVD". Is that what I need to use then to actually burn the DVD?With the authoring software, you import your MPEG2 file and create a DVD.
And will that take less time to make copies then?
What is the latest best freeware for making copies of my own DVDs?
By govtdog in forum DVD RippingReplies: 5Last Post: 22nd Jan 2012, 09:50 -
faster way to make multiple home dvd copies
By DirtBikeMike in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2010, 12:37 -
Ripping DVD Home Movies
By quxote in forum Newbie / General discussionsReplies: 4Last Post: 29th Jul 2009, 15:55 -
new to making home videos, canburn to DVD but NOT as one movie ! ??
By DoktorDave06 in forum Newbie / General discussionsReplies: 9Last Post: 10th Feb 2009, 14:25 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03
