Can anybody tell me why my PC crashes everytime i try and play a mpg2 file in WMP?? I have not had the problem before,and it just startet doing it. I have tried reinst. winXP did not work,i have reinst all codecs,did not work..
If it aint broke, donīt fix it.
HAPPY 100th HARLEY-DAVIDSON
Keep up the assembly line Willie G. -
I have the exact same problem!! All I had to do was click on the file and explorer would crash. As a temp fix I created a new user on xp, logged in as the new user and I no longer have any problems. Would still like to know why it does this though!!
Just a question, can you play the mpeg2 file with another program? I could but it wouldn't play properly, something about direct draw not being enabled!? -
I'm bumping this one up from quite a long time ago because I am having the same problem.
I don't know what the deal is. I couldn't get PowerDVD to work, it would crash when I tried to play DVDs. So I used WMP for a long time. I thought that the program Showshifter might have been causing the problems. I recently tried to install DirectDVD, during the installation, it was unable to get past the point where it says it was installed the dvd decoder and AC3 software. I uninstalled Showshifter and ran the DirectDVD installer again, and it worked this time. It worked for several different discs, however, when I tried it later in the night, it would stop responding when I tried to play the DVD.
PowerDVD still does not work, it just crashes. WMP does the same as DirectDVD, it just stops responding. This is becoming very frusturating because my PC is my only way to watch DVDs. If anyone has any ideas, please help. Thanks.
-Brandon -
Goto "Add-Remove Programs / Windows Components", and uninstall WMP. Reboot, and reinstall WMP.
Any difference? -
Well before your reply, WMP started working again (responding), however, now it gives me an error that says there is a problem with digital copyright protection. Clicking "more info" explains that it is a problem with the dvd decoder. Any ideas?
Avidemux Crash Problem
By rock99 in forum SubtitleReplies: 7Last Post: 5th Feb 2010, 07:09 -
altDVB Problem crash !
By designbuyers in forum DVB / IPTVReplies: 1Last Post: 7th Mar 2009, 20:55 -
Weird Problem with MPC and WMP
By set69 in forum Software PlayingReplies: 4Last Post: 11th Feb 2009, 22:47 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 00:38 -
WMP/REAL Player - Some of my old videos as well as new are playing weird?
By Akabane Kurodo in forum Media Center PC / MediaCentersReplies: 2Last Post: 5th Jul 2007, 14:12
