Hi all, I dont normally get this problem burning VCD's, but with this particular one, I will drag the files over to burn fine, but once the burn process start's, I get these messages 'The parameter is incorrect' 'error reading data' and than it aborts the burn. The VCD is 79 min in length.
Any help would be appreciated![]()
Cheers Rav.
Have you tried running it through TMPGEnc again at the standard VCD setting? This usually fixes it.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
Failing to get 16:9 display!
By osmancik83 in forum Newbie / General discussionsReplies: 1Last Post: 27th Nov 2010, 18:46 -
Failing burner?
By Constant Gardener in forum DVD & Blu-ray WritersReplies: 2Last Post: 3rd May 2010, 12:57 -
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
Burning Failing in Nero 7
By Osaka in forum Newbie / General discussionsReplies: 11Last Post: 10th Sep 2007, 14:03
