A friend of mine is trying to copy a video tape. He said the picture is coming through clear on the copy but the audio is cutting out. He used the same copying setup to make copies of other tapes with no problems.
My questions - is this some type of MacroVision/copy protection type of thing. I was under the impression that Macrovision distorted the video, but I haven't heard anything about audio scrambling.
Any help figuring this out would be appreciated.
Thanks,
E
It is usually on the video, but it really wouldn't surprise me if...
Hey, this is REALLY the wrong forum for this, isn't it?
- Gurm -
I couldn't find a better forum - I figured people who did a lot of ripping would know the most about copy protection. Has anyone had this experience with audio and copy protection?
Thanks. -
I have never seen it in the audio i've alway's found it in the video. I think it's another problem
Are we copying tape to tape here ?
You could plug the TV into the Destination VCR while recording
and check the audio is working ? -
The copy protection will only be on the vision. I suspect that the player is having problems picking up the fm audio off the tape .You could try switching off hifi sound and seeing if it will playback the standard linear sound track
Barrybear -
Right now he is going tape to tape - I am going to take my E60 over there and see if it has the same problems.
Thanks for your input - sounds like it is not a copy protection problem, but some sort of A/V hardware problem. I just didn't want to schlepp my E60 over to his house without being pretty sure it was going to work.
E
LG RC278 (RC-278) DVD-RW/VCR Hack Options - Copy Protection question
By vicctor in forum DVD & Blu-ray RecordersReplies: 2Last Post: 8th Sep 2013, 16:31 -
Copy Protection
By Big Jake in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2010, 15:31 -
Macrovision Has Solution for DVD-R copy protection
By Des in forum Latest Video NewsReplies: 70Last Post: 17th Oct 2008, 20:47 -
Archos AV500 recording / Macrovision protection
By bicklet in forum Portable VideoReplies: 3Last Post: 14th Mar 2008, 19:52 -
CD copy protection
By KingSeti in forum Off topicReplies: 14Last Post: 26th Feb 2008, 13:01
