Which program is the best or fastest at converting video folder to an iso image? I understand there are menu problems with image tool classic. Doesn't have to be freeware.
Most authoring applications will do that and I'm sure you've got one of those already - usually you select the recorder as being the hard disk, or some other menu option that writes to a file instead.
Also look for things like Export options in the file properties. Some applications will also write ISO images by default and / or burn from those instead anyway. -
IMG Tools (classic) d/load here or at http://www.doom9.org
What I normally do is:
1) Make a folder (eg. burnme)
2) Place VIDEO_TS folder folder (as sub-folder)
3) Make a AUDIO_TS folder
4) Point to my root dir (burnme) then generate ISO image
I then burn with DVD Decrypter. Works great no coasters to date. -
I have never noticed thatOriginally Posted by tonymac
10110101100111012011 <- The bug Bill doesn't talk about. -
yes, where did you hear thisI understand there are menu problems with image tool classic
convert video_ts to iso?
By piscian18 in forum Authoring (DVD)Replies: 7Last Post: 26th Jun 2010, 15:17 -
is there a way to convert iso to avi
By videodude1966 in forum Newbie / General discussionsReplies: 4Last Post: 16th Mar 2010, 12:00 -
Convert to .ISO
By Jomapil in forum ComputerReplies: 3Last Post: 2nd May 2009, 18:02 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 18:01 -
Convert ISO to h264
By flvgordon in forum Newbie / General discussionsReplies: 1Last Post: 14th Feb 2008, 13:13
