Ok..
so i have an mpeg2 format movie file.. which says is 480 X 480...
when i play this file, it fits the whole screen
i used mpeg2avi converter, and it said the output will remain the same (480 x 480)..
but something is diferent! when i watch this converted avi file, it now has black borders on both sides... so its much narrower and taller...
does anyone know why this is happening? and how i can fix it? is it somthing to do with the aspect ratio, and how can i change this?
any help would be greatly appreciated
thanks
epp
FOLLOW UP:
ok.. if i right click on the mpeg2 file icon.. and goto properties.. it tells me the file is - horizontal - 540
vertical - 480
so obviously mpeg2avi is loading it in at the wrong size... is there any way to fix this? i just dont understand why the program would cut it down before its even been processed
thanks
ep
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
Problems with mpeg after conversion, or with original avi - help
By krisbee in forum LinuxReplies: 1Last Post: 30th Oct 2007, 16:56
