I apologize for asking this again, but I'm not sure whether I am going about this process incorrectly or I just can't do what I am trying to do.
I have an ATI TV Wonder Card (not the All in Wonder card). It works fine in every aspect using MMC 7.1. The problem I have is when I try to capture avi via VirtualDub.
I have downloaded the wrapper.zip. I have installed the .inf file. When I installed it it looked for the .drv file and I pointed it back to the .drv in the zip. I'm guessing that is correct. Maybe not. It attempted to fine the .drv file in Windows/Cab. At any rate, I pointed it back to the zip .drv and continued.
I opened MMC and TV successfully, as usual. I closed MMC. I opened VirtualDub and selected Capture AVI. I get a series of errors (the same as before the installation of the wrapper.zip objects. The errors are:
1. BtVID: Failure loading VXD driver.
After that error, I get,
2. Error 418: Devis is already in use (MMC is closed)
I then get the error,
3. VirtualDub cannot connect to the desired capture driver. Trying all available drivers.
4. PANIC - VirtualDub cannot connect to any drivers.
I noticed in another post that one should be able to select the drivers from a video pulldown. I don't have that option.
So is it even possible to use VirtualDub with ATI TV Wonder, or is it only possible with ALL-IN-WONDER?
I appreciate any help very much. I know that this is a 'popular' topic, and it seems that only ALL-IN-WONDER cards are being addressed specifically.
Thanks again!
i have an ati tv wonder card too and use vdub for capturing. my settings are:
352x240 mpeg 1
29.97 fps
1150 cbr
44100 khz/192 bps
divx video compression
pcm audio compression
overlay mode
i have some dropped frames but not noticeable when played back on dvd player. installed the cd-rom that came with the card. no problems capturing at this settings except for some dropped frames. win 98 o/s 500 mhz celeron 319 mb ram -
the tv wonder is a tricky card to use with vdub, no doubt.
it took me lots of tweaking but I finally worked it out. however I wasn't very impressed!
for acceptable results, I suggest you use powervcr 3. It works great for me as it does real-time mpeg2 encoding and I've never dropped a frame. -
I had the same problem, tried everything, including installing the wrapper.. No go... Finnaly said to heck with it and use PowerVCR...
ATI or NVIDIA capture card for VHS?
By Smile_M in forum Capturing and VCRReplies: 1Last Post: 13th May 2010, 06:43 -
Upgrade video card to ATI HD4670
By hulinning in forum Media Center PC / MediaCentersReplies: 2Last Post: 9th Jan 2009, 19:55 -
need ATI TV Card replacement
By kisrum in forum Newbie / General discussionsReplies: 3Last Post: 21st Nov 2008, 20:17 -
I have questions about this ati all-in-wonder pci-e card
By yoda313 in forum ComputerReplies: 0Last Post: 6th Sep 2008, 09:23 -
ATI Aiw card in Linux?
By Nelson37 in forum LinuxReplies: 9Last Post: 10th Apr 2008, 13:25
