when i have a dvd to backupi open dvd decrypter and rip it to my HD then i open nero record and open the movie on the HD
the next thing i do is disable the extras and set only dts if it has it if not i use 5.1
Then i uncheck the subtitals
then i burn the cd as a nero IMAGE on my HD and delet the DVD decrypter files then last but not least i burn the movie on a Princo DVD-R white top
The problim i get is when i play the movie all i have is a black scren for a long time before the menue comes up and when i say play movie it sometimes takes another 3 mins with a black screen again befor the movie starts
AM i doing anything wrong i an not touching the menues selection in nero record
Hi rcmpayne.
My guess would be the "black screen" is actually the image that replaces the titles you disabled.
The problem with Recode is that, while it does allow you to delete titles, it replaces them with a fixed-image for a lenght of time equals to the duration of the original title.
So every title you disabled that used to be played before getting to the menu has been replaced by a black screen.
The same thing applies to the disabled titles that were played just before the movie.
ouch!, Disney DVD's spring to mind with all those trailers pre menuOriginally Posted by ddlooping
one simple fix is that you can just use Ifoedit and select delete playback for those titles if your player will accept it
or mod it to start with the Menu by changing the commands but that's something I wouldn't do as you never know what commands you are skipping
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 21:00 -
Wireless prob?
By Immortal25 in forum ComputerReplies: 4Last Post: 3rd Jun 2009, 07:55 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 05:33 -
MPEG DV prob
By mainegate in forum ffmpegX general discussionReplies: 0Last Post: 24th Aug 2007, 17:01
