ive already converted my movie from 2cd divx into SVCD.
this makes me 2 big mpeg files.
are there any program that can tell me where to cut the files so that the first cut half will fit on a cd..
cutting both in halves makes them fit but then i need 4 cds.
or should i join those 2 big files and after that cut it in three equal sized pieces. ?
/negoti8
Results 1 to 1 of 1
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 13:19 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 08:46 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 04:14 -
Cutting File size through muxing HD Audio
By Mastablastacious in forum EditingReplies: 1Last Post: 4th Feb 2008, 02:18
