  1. I'm using DVD2SVCD. I used ver 1.1.0 and 1.2.0 and downloaded the 'stable' version of besweet. But when I get to the stage of besweet, it crashes (besweet in particular). I've since changed mobo, CPU since I was last able to run DVD2SVCD fine. Any way I can incorporate a different audio program into DVD2SVCD or any fixes?
    Thanks.
    Asus A7N8X dual channel (nforce2 400)
    Athlon 3000+ barton (oc'd to 2.25)
    2 x Corsair 512 3200 XMS
    XP home edition
  2. I had the same problem for weeks -- Error with Windows XP, DVD2SVCD and BeSweet while converting DVD's to SVCD. I was finally able to determine the cause of mine --- CPU instability due to O/C @ too low a VCore.
    Many times a system that seems 100% stable and run everything else fine will crater during audio and video encoding. Mine was intermittent, with BeSweet sometimes completing, but more often than not -- BeSweet would just crash and produce an error with an option to send info. to MS.
    Audio/Video encoding is VERY CPU intensive and will cause errors where other tests (SANDRA Burn-in, 3DMark, etc.), will not. Try running the latest version of Prime95 (23.7.1 or greater) and execute the "Small FFT's" torture test. This isolates the CPU and gives it a thorough thrashing. Mine would pass the previous versions of Prime95 for 24 hour loops, but with the newest version and this test, it failed within 30-45 minutes -- clueing me in as to what may be going on with BeSweet. If you want to pound the RAM -- run the "Blend" torture test overnight.
    I bumped my VCore to 1.725 from 1.70 and all is good !!!
    Give it a shot !!
    BTW -- I have a Athlon XP 2500+ (Barton) at 2.3GHx (3400+), 12.5X mulitplier and 185MHz FSB. KT-400 based mobo -- wish I had NForce2
  3. I'm a Super Moderator johns0's Avatar
    canada
    Besweet will crash if you are encoding an avi file with a frame rate with something like 29.9650,check with virtualdub if thats the case,its not always system instability.
  4. I had a number of fights with that ware. My advice..? keep your fists up untill you or the ware is down and ko'ed... 8)
  5. Originally Posted by Ripper2860
    Give it a shot !!
    Thanks! Lowering the CPU settings to stock fixed the problem. What cooling system do you have?
    Gladiator H.S.
    Delta Fan
    Ear Plugs
    P.S. I just got my system up a few days ago so I'm still playing with it.
  6. I use a Vantec AeroFlow w/ TMD fan (70mm). Good cooling w/ a relatively quiet fan -- dumped my Gladiator/Delta (too noisy) quite some time ago and went for an Alpha 8045 w/ 80MM Sunon fan, but my new mobo doesn't have mounting holes, so now I have a Vantec. It's really a pretty good H/S with performance close to the Alpha.
    Prime95 is an excellent tool for testing. If there is any weakness it and audio/video encodes will reveal them. IMHO -- It ain't stable if it can't pass 24 hours of "Blend" Prime95 torture test.
    Here are my spec's ...
    Soltek SL75FRV (KT400) w/ AMD AthlonXP 2500+ Barton @ 2.3GHz (3400+) -- 185x12.5 and 1.725 vcore | Vantec AeroFlow | 2x512MB Kingston HyperX PC2700 - CAS2, Fast, 1T, 8W, 4-way | PNY GF4 Ti4200 128MB -8XAGP | Hercules Fortissimo II | Antec SX-1030 case w/ Tru430 PSU | 2x Maxtor 80GB 7200 RPM ATA133 | Pioneer 116 DVD | LiteOn 32x CD/RW | WinXP Pro | Prime95 23.7.1 Tested Tough
  7. Hi
    guyz
    how can i fix this problem i have AMDk6 3D Processor with 120 ram.
    DVD2SVCD use to run with no problem before but now besweet crashes.
