Does anyone know of a cheap tv tuner card (under $100) that i can also hook my tape video camera up to so i can put video and audio onto my computer.
Results 1 to 13 of 13
This depends on what outputs you have on the camera. This determines what inputs you need on the card. Your camera should have some form of analog output but it may be composite or S-Video, and you need to find out which in order to determine if any particular card is suitable for your needs as the budget capture cards tend to support one or the other but rarely both.Originally Posted by pimkins27
Thats composite.Originally Posted by pimkins27
Now hopefully someone who knows lots of different capture cards can reccomend something. -
haha, i was thinking and if i get just a tv tuner then hook my VCR up to it and plug the video / audio into that will that work...has anyone came up with this low of an idea or have tried it?
Do yourself a favour and spend the money on the Canopus ADVC-100 capture device.
Assuming you will be working with a lot of home made videos this is really the best solution since it will convert your analog cam footage to DV AVI which is very easy to edit and manipulate with a variety of programs.
TV tuner cards are best at capturing footage that does not need any kind of extensive editing.
The CANOPUS ADVC-100 normally goes for $300 but sometimes you can find it for as low as $250 if you go to eBay or use a price search website such as PRICEBRABBER.COMOriginally Posted by pimkins27
It connects to the computer using FIREWIRE or aka IEEE 1394 (SONY calls it i.link).
On the LEFT HAND side of the screen click on CAPTURE CARDS and you will find that the CANOPUS ADVC-100 is the top USER RATED capture card (well actually it is an external device).
- John "FulciLives" Coleman
P.S.
The CANOPUS ADVD-100 will work with a WINDOWS PC as well as an APPLE MAC"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Well do you want something that works or not?Originally Posted by pimkins27
yeah well im 15 with no job..do u want me to pick money off the trees outside?
Try this TV tuner card from Leadtek. It has composite video input for your camera. With your XP 2800 you should be able to caputre MPEG-2 at high enough bitrates to make decent quality DVDs and SVCDs. You can also capture AVI and MPEG-1 with the card. I bought one for my father and even his 1.1ghz celeron captures good with it. To get the best captures you should avoid multitasking while capturing at high quality, use a program like enditall2 to close background programs before capturing, and disable some of those pesky windows "services" that are rarely needed.
http://www.newegg.com/app/ViewProductDesc.asp?description=14-122-132&depa=1
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Hook up Gamecube to capture card and TV at the same time
By nonoitall in forum Capturing and VCRReplies: 0Last Post: 10th Feb 2009, 07:01 -
tv tuner card help!
By johanc in forum Video Streaming DownloadingReplies: 2Last Post: 7th Dec 2008, 07:02 -
Need recommendation for TV tuner card
By Djinn252 in forum Newbie / General discussionsReplies: 20Last Post: 27th Jul 2008, 04:30 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
