I am about to author my first DVD. I have convert my avi file to m2v using MainConcept 1.4, and audio to ac3. My file is 25fps as it is PAL. Do I need to run it through Pulldown to convert it to 29.97fps before authoring it? I am planning to use either DVDLab or DVD Maestro. Is there any suggestion as to what authoring software I should use?
Thank you.
The correct framerate for PAL is 25fps. No pulldown or conversion to 29.97fps needed, assuming you want it to stay Pal. 29.97fps is the framerate for NTSC. If you want the final result to be NTSC you have more work to do.
Convert 24p .mov to interlaced 25fps PAL
By Cotswold in forum Video ConversionReplies: 6Last Post: 25th Mar 2012, 15:50 -
720p conversion of PAL 25fps to NTSC 59.94fps using Handbrake?
By texas1 in forum Video ConversionReplies: 7Last Post: 29th Jan 2012, 11:06 -
converting PAL (25fps) to NTSC(23.97fps) with audio
By drew24 in forum MacReplies: 6Last Post: 21st Dec 2009, 09:45 -
12.497fps AVI --> 25fps PAL MPEG
By DRP in forum Video ConversionReplies: 3Last Post: 4th Jan 2008, 02:39 -
PAL speed-up: 24fps to 25fps video, how?
By JoachimS in forum MacReplies: 16Last Post: 26th Oct 2007, 14:39
