I have a dvd that I cant seem to rip, I have never had any problem with this before and if any one has any ideas on what to try or maybe a setting that can be changed I would really appreciate it. I have used smart ripper and dvd decrypter. I forgot to mention it says it is havin read errors
If at first you don't succeed; call it version 1.0
Try using AnyDVD by Slyfox software...it automatically decrypts the movie immediately upon disc insertion. Now, with this program installed you can use ANY program to rip the dvd...Clone DVD, PrassiDVD, Pinnacle Instant Copy ect...ANY of them, it automatically makes the dvd decrypted and able to rip with any program that does not support decryption..I didn't believe it myself but its a wonderful little program. If you use it with CloneDVD you can make an 8 gig dvd into a single layer dvd with EXCELLENT quality in about a total of 2 hours. Don't forget it could be the disc itself....I have run into this problem myself and tried another dvd from somewhere else. There weren't any scratches on the disc just a bad factory press I presume. In addition, have found less problems using Slyfox's AnyDVD program...you may way to try that first.
I appreciate the advice, but I stuck it in my dvd writer drive instead of the dvd-rom I usually use to rip and it worked. But I will get anydvd because I have heard alot about it.
MPEG-2 edit/save, edit/save, edit/save... cycle
By KZemunski in forum Newbie / General discussionsReplies: 8Last Post: 26th Dec 2010, 14:55 -
The One Thing That Can Save HD DVD
By cracula in forum DVD & Blu-ray PlayersReplies: 12Last Post: 19th Feb 2008, 12:52 -
save recordings on DVD.
By andy66 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Feb 2008, 16:47 -
Petition to try and save HD DVD
By NICEBUD in forum Latest Video NewsReplies: 45Last Post: 28th Jan 2008, 00:04 -
Can I save my DVD?
By GoBabylon in forum Newbie / General discussionsReplies: 8Last Post: 11th Jun 2007, 22:37
