Problem: I get the Error window that says "No drivers detected" message. As soon as you click OK, the entire flash program closes. The underlaying utility "found drivers" window is empty. the 411s shows up in both the boot up and in Device Manager. I have not burned anything yet but it does play a CD.
I have a stand alone Win98Se, 1GHz P-3, 512ram, ASus Mobo ATA 133. My current IDE config is:
Primary (80 pin) Master, 80Gb HDD
Primary Slave, Zip 100
Secondary Master (40 pin), 411s
Secondary Slave, LiteOn CDrw
Note on mobo: I think that just the Primary IDE can do the 80 pin ribbon (blue connector).
Additional PCI IDE controller card/ATA 133- Second HDD- 40Gb for video use (will soon be changed to 120Gb)
I have tried to:
1. uncheck DMA on both LiteOns
2. disconnect the ribbon connector from LiteOn CDrw, 40GB HDD.
note: tried to disconnect Zip but computer would not boot up!!
3. run in Dos mode (said that it was a bad command and file could not be found- even though it was there).
4. redownloaded 3x to be sure that the file was OK.
5. ran exe file from different partitions and folders including c root and desktop.
What should I do now?? Thanks,
LarryB
Results 1 to 1 of 1
Subtitles not complete
By Antares in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th May 2011, 11:26 -
I can't rip a complete movie.
By Marccc in forum DVD RippingReplies: 1Last Post: 17th May 2010, 07:39 -
883% complete
By cryingraven in forum ffmpegX general discussionReplies: 1Last Post: 18th Apr 2009, 07:37 -
How many complete tv series do you own?
By yoda313 in forum PollsReplies: 42Last Post: 23rd Feb 2008, 05:18 -
complete audio removal
By pabloj240 in forum AudioReplies: 1Last Post: 23rd Jul 2007, 01:51
