I have some AVI files approx size 750kb each...I wanted to convert them to Mpeg so I can place them all on a DVD. I converted them using DVD2SVCD which it did fine but the format was 480 x 480 which in DVD TMPGenc Author said that is not an acceptable format for DVD. I then took the MPEG file and placed it in TMPGenc and tried to convert it to 352 x 240.. it seemed to work ok but I can still not author it. Does anyone have any suggestions..
Razz
Originally Posted by razzcal"Art is making something out of nothing and selling it." - Frank Zappa
ZippyP,
Ok I got a template , they are mcf files where do I load them ...also the files that were converted from avi to Mpeg can they be used as I deleted the original Avi's
I also checked the MPeg files I created the ones that are 480 x 480 and the v.codec name is Mpeg2 (SVCD/DVD) and A.1 Codec name is MPEG1 audio layer 2(ocx)
Razz -
Remove multiple tracks from multiple MKV files
By accoutabc in forum Video ConversionReplies: 3Last Post: 7th Aug 2011, 11:50 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
Converting and placing multiple files on a DVD
By -phenom- in forum Newbie / General discussionsReplies: 2Last Post: 8th Aug 2010, 14:27 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28
