when i get to the step when i need to add the mpg file i get
a msg "open VFAPI-aVI for menu generation but i cant find
VFAPI-aVI what i should do?(i converted the .bmp file with
TMPGEnc)
it thinks you want to use tha avi file from vfapi to create a motion menu. If you don't want that then uncheck it on the settings tab.
If you did want to use it then you need to use vfapi1.03b and add your mpeg and create a avi out of it, when you load your mpeg that window will pop up asking for the avi you created with vfapi.
what program should i use to make some menus with diff chapters?
By shadowofanubis6 in forum Authoring (DVD)Replies: 3Last Post: 1st Mar 2010, 00:48 -
My 5990 having aproblem playing Transformers Revenge of...
By cal_tony in forum DVD & Blu-ray PlayersReplies: 4Last Post: 24th Oct 2009, 12:37 -
How do you make menus for dvds....
By mmmipa in forum Newbie / General discussionsReplies: 1Last Post: 2nd Nov 2007, 13:33 -
How will I make an AVCD with menus?
By zeldAIS in forum Newbie / General discussionsReplies: 19Last Post: 4th Aug 2007, 16:12 -
Looking for a presentations program to make dvd menus
By faramith in forum ComputerReplies: 0Last Post: 1st Jul 2007, 11:00
