I finally found a program that can capture directly to dvd mpeg 2 at 352x480. Only problem is it captures at like 420 kbps by default. There is no where in the program at all to change the desired value of how many kbps to capture at. Is there anyway to change any of the values in the registry or anyway to be able to input how many kbps you want to capture at? I was lookingfora program that would let me capture at 352 x480 at whatever kbps I wanted so All I would have to do is author them and burn. I know how to do this with 720 x480 with diff programs but I have 3 hour vhs tapes that I want to fit on dvd without having to re-encode , but capturing at the calculated bitrate.
thanks
Results 1 to 1 of 1
Re: getting interactive chapter marks windvd creator 2
By tomcat862 in forum Newbie / General discussionsReplies: 1Last Post: 28th Feb 2008, 14:38 -
WinDVD creator 2 won't allow dvd
By CullenJ in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2008, 20:57 -
WinDVD Creator 2 - Subtitles Disappear
By scooter1203 in forum SubtitleReplies: 2Last Post: 11th Oct 2007, 07:39 -
Cannot get audio in Windvd creator 3 under windows vista.
By syllinx in forum Capturing and VCRReplies: 0Last Post: 13th Jul 2007, 23:43 -
WinDVD Creator 3 not recognizing .AVI
By wmrjw in forum Authoring (DVD)Replies: 4Last Post: 28th Jun 2007, 18:15
