Results 1 to 10 of 10
    Nov 2003
    Australia
    I have this movie oversized DVD and wanted to reauthor with Shrink3
    After analyzing all menus and movie are presented click on reauthor and new DVD direcotry is show but the rest of Shrink is blank or geyed out can't do a thing even with or without anydvd active/disactivated
  2. Yeah I have the same problem, the re-author doesn't seem to work at all with version 3.0 beta 5.
  3. reauthor works fine in 3beta5. you open your disk, click reauthor and a new window will open. open the main movie part in the first window, select the title track and drag it to the reauthor window. simple as that.
  4. Originally Posted by Poppa_Meth
    Wonderful except on both my computers all you get in the new window is a empty window with nothing to select. So you're saying unlike version 2.3 you need to drag all the stuff you want from the first window to the new window, weird.
    Nov 2003
    Australia
    yeah! i whish I could do that but sorry empty interface
    Method works for 2.3 but doesn't in 3
  6. ddlooping
    For DVD Shrink guides & goodies: DVDShrink.info
    My "other" site: Teaching-Tools
    Nov 2003
    Australia
    Ahh! Thank you for pointing this out
    One quickly grows used to one way of operating and in the absence of helpfiles
  8. "Ahh! Thank you for pointing this out"
    You're welcome.
    ddlooping
  9. Great website BTW ddlooping
    What software did u use to build it?
    And what did you use for the guides? Wink?
    Thanks Keep Up The Good Work m8
    KYUSS
  10. Thanks for the positive feedback, KYUSS, I appreciate it.
    The site was hand-coded using Homesite 5.
    The guides were made using "Wink", a great & free program.
    http://www.debugmode.com/wink/
    ddlooping
