First off, sorry if this answer has been posted elsewhere, but I have done searches for the terms and read your faq's, and I cannot seem to answer my dillemma.
In a nutshell, I am ripping LOTR Fellowship Extended edition. Now I did it my usual method (Gordian knot) and followed their Xvid guide. Now, of course I was missing the english subtitles during the elvish speech.
I then of course realised I need to now include subtitles, which I would like to have permanently burned.
I have followed the advanced guide, I used Robot4rip to rip the subtitles, English 2 in this case as was my understanding. I am left with a .sub and .idx file.
I configure the .avs file using Gordian Knot, which I then select permanent subtiles. I encoded the video, and no luck.
I then re did the process manually, by opening up the video, then going to filters, add vobsub, and did it that method. When I hit preview, I still see no subtitles.
I feel I am definitely adding the vobsub correctly, I see mainly 2 options. Firstly, I have not correctly ripped the subtitles correctly, and so the .idx and .sub file I am adding has no subtitles. Or, there is a problem somewhere in the encoding process that I am not seeing the subtitles properly.
When I hit preview on the virtualdub window with the vobsub filter files included, I should in theory see the subtitles?
I am not sure where I am going wrong here, but I am having no luck getting these subtitles to appear on the video.
Any help appreciated.
Results 1 to 1 of 1
Prince of Darkness
How to add permanent subtitles with AutoGK and convert to AVI DivX or XviD
By Baldrick in forum SubtitleReplies: 263Last Post: 17th Jun 2018, 16:18 -
HowTo add permanent Letterboxed subtitles to video w/ Virtualdub, SRTtoSSA
By KneeRow in forum SubtitleReplies: 20Last Post: 13th Feb 2013, 14:05 -
Permanent subtitles with VirtualDubMod
By Jomapil in forum SubtitleReplies: 4Last Post: 8th Nov 2009, 05:34 -
Permanent subtitles
By Jomapil in forum SubtitleReplies: 3Last Post: 15th Nov 2008, 05:24 -
Permanent Subtitles with VobSub
By daniscp in forum EditingReplies: 0Last Post: 18th Dec 2007, 09:42
