  1. K, i downloaded Mummy Returns SVCD off of Newsgroups and the first cd played fine on my dvd player but the second cd didnt. The second cd was choppy. HEard it was cause of the fram rate.I looked for posts in newsgroups and someone said to do this:
    <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>That odd eh? I've seen others say that too. I extracted the mpg with
    vcdgear, then demuxed with TMPGEnc and then remuxed with bbMPEG.
    Burned with Nero and it seems to work fine with no cut off of the end
    of the film. Hope this helps.</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    I was wondering what he meant by demuxing and remuxing. Can someone tell me how to do this? I want to see the end of this darn good movie Hope ya can help!
  2. That's very funny, I had the exact same as problem. Same movie too Several great dudes here gave me the exact same solution you quoted me here. Here's the link for the topic http://www.vcdhelp.com/phpBB/viewtopic.php?topic=62370&forum=3
    You can demux by using TMPGEnc under MPEG tools and choosing "Simple De-multiplex" which you give use separate audio & video files. Then use the "Pulldown" software to do the 2:3 as mentioned in the link on the .m2v file. You will then use bbMPEG to re-multiplex the new .m2v file with the existing audio file from TMPGEnc to have a perfect working mpg file ready to be burned with Nero or VCDImager. This solved the jerking/choppy problem for me.
    I think you can use TMPGEnc to re-multiplex as well, but I don't think it's as reliable for that purpose. I recall hearing stories of missing frames, audio sync and screwed pictures occaisonally.
    <font size=-1>[ This Message was edited by: TheOne2424 on 2001-10-13 06:54:40 ]</font>
  3. thanx, i think your instructions are on the right track. But im kinda stuck on the part where i have to insert the m2v file in bbmpeg. When i try to insert it, it says that it wont accept the file???
  4. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    Just follow the instructions here for BBMpeg:
    http://www.vcdhelp.com/bbmpegedit.htm
  5. Run bbmpeg >> click start encoding >> click setting >> input/output tab >> input file m2v.
  6. Ahh1 I got it now. Apparantely i was loading it wrong(clicked the "add" button) But i managed to get it worked and it burnt fine. The quality was great and happily ever after Thanx for your help!
