Hate to ask dumb questions but I am not doing very well at figuring this out. Trying to set up GSA-4040B to handle RAM disks, ideally to work with my 100H. Am I correct in assuming the recording format of the 100H is UDF 2.0 (I know that I will need authoring software regardless to work with disks recorded in the Panasonic)? Secondly, in trying to format a RAM disk in the 4040B (by right-clicking on the drive under "My computer") I do not get a format choice box (as the instructions say) but rather only an "InCD format " option which does not allow format selection. I assume this is part of Nero 6 which I have installed but how do I get around this?
Thanks in advance for any advice.
nextlife1
See the link:
https://www.videohelp.com/forum/viewtopic.php?t=187168
and it's confirmed that the LG GSA-4040B can only read, not write 2.6/5.2GB RAM discs. You also have to install the RAM drivers if you want to format UDF 2.0 discs. -
Thanks Synergy. I had actually already read that thread several times but still can't figure it out. I have reinstalled the RAM driver several times--at the last step where it says searching for installed DVD-RAM devices it completes that step but doesn't say whether it found any (should it?). Then when I put in a disk (a Panasonic DVD-RAM) and right-click on the drive icon I only get the "InCD format" and "InCD erase" options (not the DVDForm utility all the posts mention). If I choose either one it says that no disk is inserted.
Just can't figure out what I am doing wrong!
THanks again,
nextlife1 -
Originally Posted by nextlife1
Thanks Synergy--with your suggestions I got it working!!! One problem was that I did not realize that the 4040B would be listed on my PC as a "Removable drive" for the DVD-RAM function and as a "CD drive" for everything else. So I had not noticed that a new removable drive icon had been added (since I already have two for other stuff). At any rate it looks like it will now work just fine.
I really appreciate the help!
nextlife1
region free codes please: HL DT ST DVD RAM GSA T20N
By rjl24 in forum DVD & Blu-ray WritersReplies: 3Last Post: 20th Jun 2009, 18:22 -
Problems with DVD LG GSA-4160B
By Jomapil in forum DVD & Blu-ray WritersReplies: 6Last Post: 10th Feb 2009, 23:33 -
LG GSA-4160 stopped reading DVD-RAM disks.
By lennyt in forum Newbie / General discussionsReplies: 1Last Post: 8th Nov 2008, 13:56 -
GoldStar GSA-4160B stopped reading DVD-Ram disks
By lennyt in forum DVD & Blu-ray WritersReplies: 3Last Post: 2nd Jan 2008, 11:12 -
Slow DVD drive (LG GSA-H42N) problems
By cosmo09 in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Sep 2007, 00:51
