I captured a VHS MPEG2 clip using Pinnacle USB Moviebox and the
audio is in a mp2 format. My DVD player does not play mp2 audio.
In the settings option there is a field where you can convert the audio
to LPCM format.
Do I have to split the MPEG2 clip into elementary .mpv and .mpa
streams first before I convert the audio during authoring or can I
just import it and have it convert it to LPCM on teh fly during authoring?
Thanks for the help
Results 1 to 1 of 1
TMPGEnc DVD Author question/
By ingeborgdot in forum Authoring (DVD)Replies: 11Last Post: 22nd Sep 2008, 13:58 -
New TMPGEnc DVD Author Question
By Robert Simandl in forum Authoring (DVD)Replies: 1Last Post: 11th Jun 2008, 07:47 -
TMPGEnc DVD Author 3 Question ...
By ZaYoOoD in forum Authoring (DVD)Replies: 5Last Post: 3rd Dec 2007, 07:17 -
By newtie in forum Authoring (DVD)Replies: 1Last Post: 4th Sep 2007, 09:49 -
DVD Author 2 DTS into PCM 2 problem
By SteamrollerLive in forum Authoring (DVD)Replies: 23Last Post: 23rd Aug 2007, 21:35
