After I convert a SVCD bin to mpeg, I can play it using media player 6.4. But if I burn it to a CD, then it wont play in MP. I have to load it in PowerDVD or something. Why is it I can watch it in MP when its not burned? Is there a codec that let's you watch it in MP?
I'm not sure, but I think that when you burn it to a CD as a SuperVideoCD disc, the MPG gets a few more details into it which Media Player can't seem to handle and therefor can't open it, this is just an assumption, i'm not sure 100% about it.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
SVCD are what folks? That's right, normally in MPEG2.. Which means WMP can't play it unless you have the correct codec.... WMP only supports MPG1.
teamhawaii, we all know that SVCD is MPEG2, but when you install a program such as PowerDVD or WinDVD, they install a codec that makes Media Player capable of playing MPEG2 files, the problem occours that even though it can play MPEG2, it will not play them from the CD itself.
Best Regards,
Sefy Levy,
ya! what's up with that.. I wonder if the new WMP8, that ships with XP, that supposedly can play DVDs, can play SVCDs?
Lets put it this way, anything that Microsoft makes, will be the Worst Quality, the Least options, the most Hurrible Compatibility, and you people will of course love it! cause it comes with Windows XP.
Best Regards,
Sefy Levy,
if you need a codec to open mpeg-2's in TMPGEnc or to watch them in media player just shoot me an email.
installing DVD software will not accomplish this for you - you need a system installed mpeg-2 codec
Problem with Media Player Codec Pack
By brassplyer in forum Software PlayingReplies: 3Last Post: 12th Jan 2012, 07:39 -
4:2:2 Chroma codec/filter for media player classic
By tvpyvid in forum Software PlayingReplies: 8Last Post: 20th Nov 2009, 10:57 -
Vista Media Player 11 doesn't play MP3 Codec Missing
By mlong30 in forum AudioReplies: 6Last Post: 29th Jun 2008, 11:49 -
Win Media Player...codec problem?
By KevetS in forum Newbie / General discussionsReplies: 4Last Post: 12th Apr 2008, 19:08 -
Windows media player 11 playback codec for DV AVI
By Canadian* in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 27th Mar 2008, 18:56
