  1. Hi All,
    I am currenlty using DVio - but it is a bit too plain for me.
    I want the raw cature of dvio with a bit more ...
    2 features I would really like are ..
    preview screen and timed capture.
    It looks like Scenalyzer has it , but I was hoping for a free product.
    virtualdub sounded right, but from what I read it is not the best given I am coming from DV (canopus)
    Any suggestions?
    Allen
  2. sorry ..
    anyone play with virtualedit lite for this task?
  3. anyone have a comment for me ?
    Allen
  4. About all I can reccomend is what you don't want to buy - Sclive.
    Yes, it has the features you are looking for plus a few other perks that will keep your puter and authoring apps happy.
    You can d/l a trial ver (which comes with a watermark, I believe) and see if it suits your needs.
    I also hunted for a freebie like you are, but had no luck.
  5. About all I can reccomend is what you don't want to buy - Sclive.
  6. Ok thanks
    did you compare sclive VS. Scenalyzer?
    Allen
  7. yep - same answers as those in your other thread
