Results 1 to 16 of 16
  1. Hello, i ripped the movie with dvdshrink. from a dvd9 to a dvd5. And now how do i burn the movie?? i got some ts and vts files?? please help me.
    Jul 2003
    michigan
    you need a burning applicatioc, i use nero. a free one is burn at once
    Dec 2002
    Bristol, United Kingdom
    imgtool for the image
    dvddycrypter to burn
    I am new to this but its worked for me.
    Download them from the tools section.
    Yeah Baby!
  4. but is it possible to load the movie_ts file into nero?? and then burn ity?? because when i load the movie-ts into nero and then try to burn it i get a message.
    Dec 2002
    http://www.polarhome.com:793/~afonic/shrink.htm
    use this link. it should help you
    Yeah Baby!
  6. okay thanks alot. that should work. I'll try it
    Montreal, Quebec, Canada
    Use the wizard in Nero. Choose DVD-VIDEO. Open your folder with the Shrink files in the right pane and select all of the files (not the folder!). Drag and drop them onto the VIDEO_TS folder. (red one in the left pane). Then burn.
    Morloc
  8. when i try to rip a dvd i get an error that the dvd is protected. and dvdshrink will stop the ripping. what to do????? need help...........
    Jul 2003
    michigan
    rip with dvddecrypter
  10. the message is:
    dvd shrink encountered an error and cannot continue.
    The error:
    Failed to read from file.
    The reason is: copyprotection error.
    But the problem is that the region of my dvdburner is not the same as the dvd???? But i cannot change the region of my dvdburner........i got a windows xp operating system.......
  11. okay i went to your link and ended at this site http://www.dvdidle.com/dvd-region-free.htm but i only can download a trial version
  12. yes. Download the trial version.
    you can look at it at the tools option on the left.
  13. I do this method. I downloaded a trial version of DVDXCOPY XPRESS from 321 Studios. I use DVDXCOPY XPRESS to read my DVD and convert it into my Video TS Files. Then , without closing DVDXCOPY XPRESS, I burn the Video TS files created by DVDXCOPY XPRESS with NERO. Works every time and as long as you do not burn with XPRESS, your trial lasts forever. XPRESS picks out just the movie protion of the DVD and makes it into burnable Video TS Files. Works great!
  14. hey all you guys thanks for the replies only i got one problem. I ripped a movie from dvd9 to dvd5 with dvd shrink and also used regionfree. But when i burn the video_ts i get an burn error at 99 %
  15. What are you burning it with? Here is how to do it with Imgtool: http://menuedit.dimad.net/ht_burn.html
