After I make my menu and it goes back to svcddvd it freezes up. My os is Windows 98se please help me solove this problem.
anyoneGuest
Originally Posted by anyone
Then: Do an Automatic Update, so you get the newest version.
If you don't want to update, do what I had to do before it was changed:
-when you have pressed Encode in the old DVDMenumaker, its window disappears, but the program for some reason of its own stays in memory. So you call up the Windows TaskManager by pressing Ctrl-Alt-Del (once!), select DVDMenumaker (or, as the case may be, 'DVDMenuMaker (Not responding)'), and click End Task, bottom left.
You get a window and click End Task again. DVDMM disappears for real now, and SVCD2DVD gets back to normal.
Hope this helps..
Callan -
Callan - update is not ready yet. Eta this week.
T. TomGuest
Anyone,
I have the same problem using 98SE. The answer is to wait several minutes.
Eventually the Menu window will disappear and the SVCD2DVD window reappears but is not fully formed. At this point, go to Task Manager (ctrl-alt-del) and close MenuMaker. This will allow SVCD2DVDto continue.
Click Start and let the program do its thing. And you will end up with the
menus you created.
Creating A DVD Menu
By 557953 in forum Authoring (DVD)Replies: 8Last Post: 19th Jun 2008, 08:41 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
Creating Menu's
By wristar in forum Authoring (DVD)Replies: 4Last Post: 10th Oct 2007, 19:42 -
creating a DivX menu
By shankie in forum Authoring (DVD)Replies: 14Last Post: 29th Jun 2007, 11:28 -
After creating a video CD I only get the menu to appear...help
By dave4500 in forum Newbie / General discussionsReplies: 4Last Post: 25th Jun 2007, 01:23
