Results 1 to 13 of 13
  1. Does anybody knows how to make a SVCD work on a Philips DVD750?? Propably i need a P-code to activate the SVCD option. Can anyboby help me with this
    Thkx
    Thkx,
    Ejunkie
    Jun 2001
    suisse
    Yes you need a p-coe,
    I can help you but you have to tell me what firmware do you have and what you're looking for (region 1 or 2, pal or ntsc, etc...).
  3. Hi Look my new topic
  4. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    i've got firmware 6.2 000111 P2 3.26.5.
  5. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    i've got firmware 6.2 000111 P2 3.26.5. Region 2 PAL
    Jun 2001
    suisse
    Sorry, I have no code for this firmware (only 7.12 or 9.24,25,2. You shoulb maybe try to upgrade your player...
  7. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    OK... I'll will try to upgrade to firmware 7.2 Can you give me the P-code for this Revision?
    Thkx
    Thkx,
    Ejunkie
  8. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    OK... I'll will try to upgrade to firmware 7.12 Can you give me the P-code for this Revision?
    Thkx
    Jun 2001
    suisse
    055 = pal, region 2, svcd, beep, 6 audio, s-video, ...
  10. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    Thankx.... I've upgraded the firmware from 6.2 to 7.12 and then entered the code. SVCD working properly now. Topic closed
    see ya
    Thkx,
    Ejunkie
  11. Can I make my Philips 710 play SVCDs like this? I'm on formware 9.21, will an upgrade to 9.28 give me SVCD? It's a PAL (UK) model
    Jun 2001
    suisse
    Hi,
    No it's not the p-code, for the firmware 9.28 you have to enter p-code 009.
    Don't forgett to write your original p-code somewhere...
  13. I thought that SVCD on the Philips 710 is only possible when set to region 1, or does firmware 9.28 makes a difference in this respect. Or is P-code 009 region 1?
