Be a bit careful of the bulkpaq orange 4x, I have been using tese disks with no problems for quite some time, but amongst my last lot there were 25 that would only burn at 1x speed. The centre part should be white but on these ones it was silver, they were marked up 4x and apart from the silver inner looked identical to the 4x ones.
life's a shit sandwich and everydays a bite
cannot find any media code on the duff disks
life's a shit sandwich and everydays a bite -
How are you looking for it ?
You need to use something like DVDinfo Pro or something similar. If it genuinely does not have a media code, it will report back something along the lines of "media ID not allowed", in which case that might explain a lot ! -
This is all the info I can find, They are marked up 4x on the disc and my writer is a 4x writer
Manufacturer : Princo
Code : -
Disc Type : DVD-R
Usage : General
Recording Layer : -
Recording Speed : 1 X
Capacity : 4.38 GB
4706076672 Bytes
Additional Capacity : -
Overburn Capacity : -life's a shit sandwich and everydays a bite -
Problem solved - PRINCO !
The quality of these can be good... but more often than not they are a bit flaky. I have certainly had mixed results from those guys.
What happened to the orange cone? Vertical Lines in deep reds and oranges.
By Sullah in forum Video ConversionReplies: 12Last Post: 24th Jul 2011, 17:01
