After using DVD decryp then using dvdshrink I cant play the created files using Windvd4. The files play ok after using DVD Decryp. Anyone help please
Thanks Roy
Why are you using DVD Decrypt and then Shrink when Shrink alone will do the complete job of ripping and creating the files you need from your original DVD.
I do 99% of my backups directly on DVD Shrink.No DVD can withstand the power of DVDShrink along with AnyDVD! -
DVD Shrink will not work for POTC, as well as other Disney movies. I play it safe and use the same method as Roy47.
Roy what DVD are you trying to back up? -
I have backed up all my Disney films and both MIB's using DVDShrink and Nero, no problems at all.
The odd things is, I purchased Finding Nemo on region 1 and it wouldn't play in my set-top box (multiregion, no encoder installed) however, when I ripped it with DVDShrink, the burnt copy worked fine.
Thanks -
"DVD Shrink will not work for POTC, as well as other Disney movies. I play it safe and use the same method as Roy47.
Roy what DVD are you trying to back up?"
That's funny, I ran POTC directly through Shrink and got a perfect copy of the main movie - not extras!! In fact there is not Disney movie I have not been able to backup woth DVDShrinkNo DVD can withstand the power of DVDShrink along with AnyDVD! -
Hi all.
Roy47, are you using WinDVD "DVD from folder..."?
If yes, the "shrunk" files need to be in a folder named "VIDEO_TS".
If no, what "mode" are you using to play the files, and do you get an error message?
I never had any problems backing-up DVDs with DVD Shrink, whether Disney's or others.
I also never had the need to use DVD Decrypter (except to write my guide).
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 23:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 21:31
