OK I posted something like this before and all I got was ya i got the same problem.. I can connect to my MMC, but when I start capturing its covered in a big green blob, like if it was macrovision, and its not cause my source is satellite, and I was using cable before and it still did it, no DVD, no VCR, only satellite/cable and it gives these green blockig problems, opening MMC and then closing it and then opening VirtualDub? Did that, still nothing, i dubbo whats wrong, of anyone can gimme any ideas or link plz do so, i do not want to keep posting this question over and over again, but plz, thnxs...
P.S. Excellent Help Website I might add.![]()
Of course you have to close MMC.
Did you choose the right "source" (pull down under "Video"
Did you choose the correct driver under Video, last option in pull down menu? Must be ATI and not for example Microsoft WDM...
oh man, the video driver under the Video pulldown is not there, all i see is my Logitech cam a dnthe WDm u mentioned, how do i add it there, and thnxs alot
VirtualDub Capture Pin problem.. (EasyCap) [SOLVED]
By muzzmikkel in forum Capturing and VCRReplies: 0Last Post: 22nd Jan 2012, 11:05 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 11:26 -
Capture Card and Virtualdub Problem
By TV107 in forum Capturing and VCRReplies: 3Last Post: 29th Nov 2008, 17:35 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 05:11 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 02:28
