I've had my Nec 1300a writer for about 6 months and never had one problem with it. Then I upgraded my motherboard/cpu to an XP 2200 and I also upgraded my OS from 2000 to XP. For some reason I can't burn CDRs. I can still make backup DVDs fine but I can't burn CDs. I've tried everything you can think of to get it to work and have spent countless hours on it. I've downloaded IDE controllers, ASPI, ATAPI, and upgraded all burning programs. All my burning programs recognize my drive and when I hit the burn button, it freezes up my computer. I would surely appreciate any input on this matter. Thanks.
It can't hurt to try this IDE REFRESH JUKKA POSTED elsewhere again here:
routine for WINDOWS XP below
Open RegEdit
Find the following KEY
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\000x
The last four digits will be 0000, 0001, 0002, 0003, and so on.
Under each key, delete all occurences of the following values:
MasterIdDataChecksum
SlaveIdDataChecksum.
Reboot the computer. Windows will now redetect DMA settings.
I found this at
http://www.tongfamily.com/000392.html -
i'm having similar problems with an nec 1300 drive, can anyone post how to reset IDE settings on win98se?
NEC ND-4550A Problem
By drakster in forum DVD & Blu-ray RecordersReplies: 3Last Post: 3rd Jul 2010, 12:25 -
NEC NDH80 Gone B&W
By bawpcwpn in forum DVB / IPTVReplies: 1Last Post: 11th Jun 2008, 14:23 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 21:07 -
NEC 4571A problem
By rmorrison1 in forum DVD & Blu-ray WritersReplies: 18Last Post: 1st Jul 2007, 12:35 -
NEC NDH81
By babagoi in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 19:05
