I made a seperate post earlier pertaining to the DVD audio streams being several seconds longer than the video and hence despite the tools I used, the audio was off sync from video. This still holds but there is a seperate problem i am apparently getting from DVDx. Three different DVD rips I attempted all resulted in offsync audio, and dudring the encode of the 2nd pass @ about 80% or so of the encode, i'd get an error message about and audio buffer overflow orunderflow and if I would like the block filled withan audio blank or something. I click ok, and no matter what, in the end, the audio is significantly off sync from the video. I didn't have prbolems with DVDDecrypter-->DVDx before reformatting my hard drive, and now I can't do a single working encode! If it helps, I had problems with DVDx like this when I first installed Win 2000 on my machine upgrading from Win NT 4.0, the windows 2000 installation before the recent format was an upgrade from 98 SE, while the recent installation of 2000 was straight from the DOS prompt. Any insight anyone?
Audio Sync Problems
By eon_designs in forum Blu-ray RippingReplies: 2Last Post: 8th Dec 2009, 10:49 -
Audio sync problems
By sticklebrick in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2007, 15:14 -
Audio sync problems
By jelockwood in forum ffmpegX general discussionReplies: 1Last Post: 30th Jul 2007, 13:03 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 07:22 -
Audio sync problems (again!!!)
By MadMaz in forum Newbie / General discussionsReplies: 10Last Post: 30th May 2007, 21:42
