I just upgraded from windows 98. Does anyone know how to get that network icon to appear. You know the one the appears in the bottom right hand corner each time you connect to the internet. It tells you how fast you connected and how long your current session has lasted. It appeared the first few times but now it doesn't. It's really frustrating since now each time I want to disconnect I have to Log Off the computer. Not like before where I could just click on the little network or 2 computer icon and click on disconnect. Please help.
Open My Network Places on the desktop or thru control panel. Right click the Icon for your internet connection. Then check the box that say show icon. That should do it.
It worked but once I disconnected and reconnected I had to do it again. How can I make it permanent so that it will appear each time I connect? (there is no Apply button, Win xp pro)
Just a quick question. How do you connect? Dial-up or Broadband (always connected). How many entrys are there in your Network Icon(what are they).
Windows Media Center .wtv 720p (60fps) to Xvid AVI (24fps) in Windows 7
By cg-realms in forum Video ConversionReplies: 0Last Post: 7th Jan 2010, 18:47 -
Windows 2003 or Windows 2008 based on my server specs & needs...
By retroborg in forum ComputerReplies: 18Last Post: 23rd Jun 2009, 06:29 -
Subtitles in Windows 7 (64) and Windows Vista (64)
By NeoCyrus in forum SubtitleReplies: 2Last Post: 11th Feb 2009, 21:00 -
How similar is Windows Server 2008 to Windows Vista?
By davidsama in forum ComputerReplies: 6Last Post: 12th Nov 2007, 10:25 -
windows mp is not playing sound on videos (but only on one windows account)
By lightsout85 in forum Software PlayingReplies: 0Last Post: 30th Jul 2007, 15:19
