i am useing TMPGE to encode AVI files captured with the Huffyuv codec. here are the filter questions...
1-inverse telecine- i capture at 640x480 30fps. how can this filter benifit by converting to 24fps
2-noise reduction- i am currently useing the default setting. can it be better? if so, how?
3-sharpen edge- does it really make a difference? my captures are perfectly smooth.
4-de-interlace- what is adaptaion?
well that should cover it. i've sat for a long long time testing everything else and i've just about got my personal preferences licked except for these filters. my pc screen is just a little to small to look for the little details that show on my 36 inch tv set. if only the original AVI files were as small as the Mpegs forVCD's.
THANKS............
OOPS...i accidentaly put this under captureing. i meant for it in conversion. sorry......
best DVD recorder filter & ATI AIW filter
By VCRcomp in forum RestorationReplies: 1Last Post: 27th Jan 2011, 18:27 -
Codec/Filter Questions
By hobbesent in forum Newbie / General discussionsReplies: 4Last Post: 17th Dec 2010, 13:38 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
ac3 filter settings questions
By THX-UltraII in forum AudioReplies: 0Last Post: 11th Feb 2009, 06:32 -
VHS to DVD with Canopus ADVC110 - mostly filter/cleaning questions
By Z-C in forum RestorationReplies: 121Last Post: 14th Jun 2007, 06:55
