I am trying to make a DVD in Spruce with the same 5 minute clip muxed 3 different ways to see if there is any difference in audio sync. This is originally a raw AVI captured with Vdub. I export the WAV file and used softencode to convert to AC3 2.0 (BeSweet AC3 files are always silent for me). I encode just the video file in TMPGENc to a 720x480 VBR 4800kbps 29.97 fps .m2v file. I am re-muxing with TMPGENc (Clip1.mpg) and bbmpeg (Clip2.mpg). I am also going to import the video and audio seperately into Spruceup. When I import the video and audio seperately (clip3.m2v & clip3.ace) all is fine. However when I import either Clip1.mpg or Clip2.mpg, Spruceup goes through the parsing operation just fine but when it finishes the video is not in the bar on the left like it should be. There is no error or anything. Also, all of the .PRA and .PRV files are created.
A side note is that when I muxed in bbmpeg, I had selected the "DVD" and SpruceUp would not import this. Said there was an "Error in the System Header" at the beginning of the parsing operation. I went back and muxed again but selected MPEG2 and SpruceUp takes the result with no errors, but as I said above, it doesn't show up in the bar on the left.
Thanks for any suggestions.
Premiere importing mts files problem
By marinteshvara in forum Newbie / General discussionsReplies: 2Last Post: 19th Dec 2011, 18:28 -
Problem with Sony Vegas importing DVDs
By aporreca in forum EditingReplies: 2Last Post: 31st May 2010, 09:28 -
Smoothness problem while importing avchd files
By effegieffe in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 3rd Mar 2010, 21:55 -
problem importing wav into EditStudio
By ecc in forum EditingReplies: 4Last Post: 20th May 2008, 14:41 -
Problem importing video into VirtualEdit
By acid_burn in forum EditingReplies: 3Last Post: 23rd May 2007, 10:07
