  1. I'm using m2v files for my svcd's, but they don't work... can i convert them to mpeg?
    -Brandon
  2. yes you can, here the method i use.
    open TMPGEnc
    Goto File -> Tools -> Merge/Cut
    Add your MPEG-2 File
    change the stream to MPEG-1
    and output the file, and it is now in MPEG-1 stream instead of MPEG-2. Ive done that before and it worked
