  1. Hi,
    can anybody tell me how to make a photoalbum with sound?
    I do not want to have a different song for each picture, but for example one song and several pictures displaying while this song is playing.
    I use TMPGEnc to encode.
    Thanks!
  2. If you have winoncd 3.8 then you can add one song per album. The song will play as the pictures show on the screen.
  3. WinOnCDPE3.8 is the best for photo albums...but when i try to add audio i have problems burning with WOCd.
    So, I now make photo albums to music using ULEAD VS5 to drop the pics into frames, set timeline for each pic (5 secs), then add an audio track and encode.
    They look great, but the result is a rather large MPEG.
    It winds up taking up much more space since the pics get repeated each keyframe.
    Oh well, it's the finished product quality that counts!
    One other note, I have found that if you encode with a high bitrate to preserve picture quality, then re-encode with Tsunami at a lower bit rate (since there is no motion), you can save a ton of space (75%). But, for some reason, if I encode in ulead at a lower rate, it gets blocky/fuzzy.
    -PUV
