This isn't so much a question as a request to all the (x)VCD makers as to what their preferred settings are.
I have been experimenting with various settings on TMPGEnc and feel that I have now found my preferred settings.
Picture Size: 352 x 288 (Pal)
I use this frame size as most of the (x)VCDs that I make are VHS conversions. Having owned a Toshiba 220SE for the last two years and its annoying SVCD sound/video sync bug, I have not gotten enthusiastic about SVCDs.
Kbps: 1400 to 1800.
This is so that the smudgyness/blockyness of VCDs is not apparent (like you need telling that!!!) and the shorter the film is the higher I will go. With the above Kbps range, I can still happily fit up to one hour of good quality video on one CD-R. Also if I wish to burn the file onto DVD+R (as I recently found out thanks to Bugstar) going above 1850kps will not work.
Audio: 48,000 Hz
The standard 44,000Hz often has a "tinny" sound to it and using 48,000Hz seems to solve this problem.
Has anyone got any other favourite (x)VCD settings and the benefit of them (or even the drawbacks of my settings)![]()
Results 1 to 1 of 1
Cole
Handbrake 0.9.5: Best settings for me?
By Pokelus in forum Newbie / General discussionsReplies: 1Last Post: 7th May 2011, 16:04 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
Best Settings
By devdev in forum DVD RippingReplies: 2Last Post: 26th Jan 2009, 10:46 -
HD Settings
By kiwikiwi in forum EditingReplies: 9Last Post: 13th Dec 2008, 16:20 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 18:53
