  1. why does smart ripper give you a cant unlock all files ? 90% of them are ok , but the ones it wont to unlock is the ones i want the most,anything elese that will work?
  2. Smart ripper 2.41 ocassionaly has this problem.
    Try using DVD Decrypter V3.1.7.0.
    Since swapping over to this, I haven't experienced this problem!
    Hope it helps!
