I have 4 different computers that I get online with, I use XP, XP proffessional and Win 98SE all four computers seem to have the same problem . When I go offline my phone line doesn't want to work anymore even when all computers are shut down I have to go and unplug phone lines to the computers that are hooked up to get a dial tone again. Its usually not even the computer that was last online with that is the culprit. The only thing they all have in common all have is the same internet server. Anyone know of a solution that I am not aware of. Is there some setting that is the cause. I use gtcom.net This problem just started 3 months ago and I have had the server for the last 2 yrs
I would try updating the modem driver first. I would also check to make sure you don't have any fax program trying to take the line when you disconnect from the internet. Hope one of these will solve your problem.
hootie29
New modem - DOCSIS 3.0, anything I should know?
By Xylob the Destroyer in forum ComputerReplies: 1Last Post: 5th Dec 2009, 20:13 -
canot connect to modem
By romanstopme in forum ComputerReplies: 5Last Post: 17th Dec 2008, 12:39 -
Which modem router to get?
By Tbag in forum ComputerReplies: 3Last Post: 1st Jun 2008, 16:54 -
Vista modem drivers.
By Poppa_Meth in forum ComputerReplies: 5Last Post: 1st Nov 2007, 10:32 -
using modem router whilst shut down
By Tbag in forum ComputerReplies: 2Last Post: 28th Sep 2007, 16:14
