I got Nero 6 thinking I would be able to burn Ritek DVD-RAM after trying to burn with 5.5.0.54 without success. Neither worked. But I found out something else. When I burned with 5.5 I would burn 2x media at 2.4 when I went to 6.0 and then 6.0.0.28 I could only burn 2x media at 2. Went back to 5.5.0.54. Also noticed lead-in and lead-out was slower with 6.0. Anyone know what's up?![]()
LG GSA4040B
Win98SE
Results 1 to 14 of 14
Well, the consensus here seems to be Nero 6 is a 'work in progress'. I still use 5.8 for most stuff. Nero wants to be everything to everybody and doesn't seem to do anything that well. I'll wait for the final version if they ever settle on it. If you got Nero problems, try the alternatives.
5.5.10.20
5.5.10.28
5.5.10.35
5.5.10.42
All before had bugs.
All after (6.0.0.0 and up) still have bugs.
The 4 I just mentioned are the sweet spot.
Edit .... add 5.5.10.54 to the "good list"Want my help? Ask here! (not via PM!)
Does that mean 5.5.10.54 introduced new bugs, or that you haven't bothered trying it yet?
I'm using 6.0.0.11 and I've had no problems at all with it, but that seems to be somewhat dependant on your computer set-up. I know a few people that have various problems with it that I don't have on my system.
Originally Posted by Poppa_Meth
I guess I'll make my first post on this site in this thread. I originally
had something like Nero 6.0.0.19 and it had issues with the lead-in (regardless of DVD format) on my Teac DV-WD50 (which I hear is basically the same as the Pioneer A06). Anyway, I updated to a newer version of Nero (6.0.0.23 ??) and it solved the problem. Everything has been smooth since then. Not one failed burn yet (DVD or CD).
So, yeah, Nero 6 probably has bugs, but they seem to be very dependent
on your specific system setup. -
nero6 does have bugs i it seems to be with lead in and around the 70-80% mark when testing on dvd player the latest ver60028b has fixed these probs maybe it isn't the media after all
Originally Posted by ThornWant my help? Ask here! (not via PM!)
I used Nero 6.0.0.11 for a while with a Pioneer DVD-106 with no inherent problems. I upgraded to 6.0.0.15 and it cracked the sh*ts badly. I then rolled back to 6.0.0.11 until I was game enough to try 6.0.0.23 and I still have that as we speak with no problems whatsoever.
If in doubt, Google it. -
My new BTC DVD-+R drive did not work with 5.5.10.20 (I installed it maybe 30 minutes ago)... but an update to 5.5.10.54 took care of it ... glad I re-read this thread ... thanks for the head's up on the newer 5.5.x versions !!! Was valuable
nero 60028 changes
Here is changelog. Hmmm... somebody talked about "small" changes...
Features Added
Added support for new features
The default book type for DVD-Video is set to DVD-ROM now to get a higher compatibility with playback devices
Added support for Windows XP for AMD64 in 32-bit emulation mode
Nero Express:
Usage of the CD database in Nero Express is simplified
The "Select files and folder window" will now be placed automatically in a position so that the content of the compilation is more visible
Removed the "New project" entry in the "What do you want to do now?" menu after recording if Nero Express was started from Nero StartSmart
The back button of the compilation page is now hidden if Nero Express was started from Nero StartSmart
Nero Wave Editor:
Added shortcuts and tool tips for all buttons in the toolbar
Nero BackItUp:
Added an option to allow rewritable discs to be erased without
confirmation
Added an option to disable the ejection of the disc after recording
Bug Fixes
Nero Burning ROM / Nero Express:
When burning UDF compilation that contain files larger than 2GB, the caching will not fail anymore
Fixed MPEG video files decoding problems under Windows 98SE and windows NT
Fixed image transfer problems when using NeroNET
Fixed crash when Nero Burning ROM or Nero Express is started from Nero
StartSmart for erasing a disc and no recorder is installed
Improved the error message that appears if an ultra-speed CD-RW is inserted in a recorder which does not support it
Only show option for DVD compilation if a DVD recorder is attached or expert settings are enabled
Fixed displaying of write speeds if a DVD compilation is selected while a CD recorder is the current recorder
Fixed show DVD compilation only if a real DVD recorder is attached
MP4-file extension is now recognized for (S) -VCD compilations
CD copy options for data CDs have been fixed
New GUI for disc label selection for NeroRobo
Added possibility to choose language and keyboard layout for boot disc created with integrated boot image
Fixed erasing speed problem with certain recorders
Nero Burning ROM:
Fixed slightly wrong calculation of size when copying DVDs
In the hard drive backup dialog, changing the disc type will no longer unselect the partition
The save track dialog will now only save tracks in reverse order for drives that need this behavior
Fixed stability problems when loading a VCD compilation containing a "PICTURES" subdirectory
Fixed incorrect display of drive speed and available space in the cache preferences
Nero Express:
Fixed access to the properties of several selected Video-CD pictures through the context menu
Enabled the main window close button in the disc copy page
Enabled text in the dialog for selecting the (S) -VCD menu
Added possibility to use integrated boot image when creating bootable discs
Nero Wave Editor:
Improved the error message that appears in the "Save Tracks as separate files" dialog if the path is not valid
When trying to save a MP3 file with a bitrate that is different from
the original, the original bitrate was incorrectly kept
Nero BackItUp:
Fixed wrong aspect ratio of the background picture when using a
Japanese system
Since only one session is allowed for DVD-R and DVD+R, display a
message if the user tries to write several sessions
Fixed starting backup on blank CD-RW disc, the disc get ejected and application ask for new, blank disc
Fixed drive locking in case CD-RW disc is inserted and "waiting forodisc dialog" appears
Fixed creating a backup with InCD formatted discs fail when more than one disc is used for the backup
Fixed system reboot when inserting second backup disc
Fixed problem with disc not recognized if InCD is installed and disc is an INCD formatted disc
Fixed incorrect time stamps of files on the CD
The BackItUp system tray icon provided context menu only in English
Improved error message that appears when not enough space is available for creating temporary files
Improved error message that appears when the burn process fails becauseof the recorder or the inserted disc
Not all temporary files were deleted when cancelling the burn process
Improved checking of file presence before the burn process starts
Improved detection of locked drive
Fixed handling of menu keyboard shortcuts
Nero SoundTrax:
Fixed stability problems when using learge audio files
Improved error message when opening a npf file which links to some non-existing files
User defined presents are now stored in a different directory than
pre-defined
Logo has been added in the about dialog
Nero StartSmart:
Fixed translation in Windows XP auto play prop-up
__________________Asus CUSL2-C [I-815PE] \ Intel P-III 733MHz \ 384 Mb SDRAM \ Asus GF4-Ti4600 \ WD 80Gb/8Mb/HDD (0:0) \ Memorex 40Max (0:1) \ Lite-On LDW-411S (1:0) \ Pioneer DVD-106 (1:1)
WinXP Pro SP1
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 21:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06
