I have some problem here with mpeg editing
Yeah, now i have 1 *. mpeg-2 file was captured by intervideo-winvcr
Oke, the problem here is the video frame detect by virtual dub is 29.970 and the sound frame is 25.000 and they are out of sync when i play it on some software player.
My only choice in virtual dub is sync audio and video by chose option - Frame rate -> Change so sound and video duration match. Its oke but it ONLY work with AVI file and not Mpeg-2 file.
Somebody show me which program could change my frame of video and sound like Virtual Dub but work on MPEG-2 file not AVI file ?!!?
Since you know how to solve your problem with Virtual Dub, why don't you use Virtual Dub mod to load your MPEG-2 file, fix the synch, and frameserve it to TMPGEnc to get it back to MPEG?
Hello. -
Thanks for your reply but still now i'm noob with frameseving, i will try search about this now, but if you dont mind
, could you show me a bit, or some useful link about my trouble, thanx in advance !
Thanks again, now i know how to deal with frameserver but i have alots of files to encode and if i do manual one per one by frameserver like this, it will take me alots of times, is there any way faster !?
Thanx but this will cost more time than frameseving. Hmm, im trying to find any program that con deal directly with mpeg-2 in editing, cutting and sync ...
Anybody know ? -
Demux into video & audio streams. Load audio into Sound Forge 7. Timestretch the file shorter or longer to synch it to the video. Save as wav. Use ffmpegGUI (freeware) to convert the wav to ac3. Author the video & ac3 to vobs & burn to DVDR.
encoded video duration different than vob duration
By fatcharlie in forum Video ConversionReplies: 9Last Post: 4th Dec 2011, 10:04 -
how to change saturation and brightness levels to match original video?
By thrakk in forum RestorationReplies: 9Last Post: 10th Sep 2011, 07:58 -
Change frame rate. Audio don't match with Video...?!
By SB4 in forum Video ConversionReplies: 2Last Post: 25th May 2011, 14:55 -
Windows Media Player - How to change the still duration?
By coody in forum EditingReplies: 0Last Post: 6th Jan 2009, 23:37 -
Change of the still photo duration vs. increase of the No of pictures
By coody in forum Authoring (DVD)Replies: 2Last Post: 8th Oct 2008, 21:08
