  1. I have P4 1400mhz with 256MB RDRAM-400MHZ and HD 90 GB 7200RPM.
    I bought the ADVC 100 and i havn`t got it yet.
    is my computer is strong enough to capture video from DVD and VHS in good quality without dropping frames?
    thanks
    ofir
  2. my machine has the same specs as yours, and it works like a charm. i get a few dropped frames. but it should work good for you.
    If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
    Want to extract audio from .vob files? Read my guide at https://www.videohelp.com/forum/viewtopic.php?t=187078
    Dec 2002
    You are marginal, but yes it should work. Huffyuv has less overhead than MJPEG, but takes up more capture space.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  4. Are you think that more 256MB RAM will solve the problem?
  5. Mod Neophyte redwudz's Avatar
    USA
    You might see a slight gain with 512MB, but if you are not having problems, I would stick with what you got for a while. If you have the money to spend, go ahead. However increasing CPU speed will always give you the biggest speed gain.
